读取Excel的记录并导入SQL数据库
2017年11月16日 23:48 本文热度 8520
准备一下,近段时间,需要把Excel的数据导入数据库中。
引用命名空间:
using System.Configuration;
using System.Data;
using System.Data.OleDb;
using System.Data.SqlClient;
你可以写一个方法,是去读取Excel文档的方法,返回DataSet数据集:
复制代码
private DataSet ImportExcelToDataSet(string virtualPath, string sqlQueryStatement)
        string excelConnectionString = DB.ExcelConnectionString(Server.MapPath(virtualPath));
        OleDbConnection dc = new OleDbConnection(excelConnectionString);
        OleDbDataAdapter da = new OleDbDataAdapter(sqlQueryStatement, dc);
        DataSet ds = new DataSet();
        da.Fill(ds);
        return ds;
复制代码
导入数据库,在数据库中,需要创建一个表来存储Excel导入来的数据:
接下来,你可以使作SqlBulkCopy的方法进行复制数据库:
复制代码
try
            string cs = ConfigurationManager.ConnectionStrings["InsusSqlConnectionString"].ConnectionString;
            using (SqlConnection sqlConn = new SqlConnection(cs))
                string sqlQueryStatement = "SELECT [Material],[Plnt],[Level],[Item],[Component],[Object description] FROM [Sheet1$]";
                string virtualPath = "~/App_Data/Book1.xlsx";
                DataSet ds = ImportExcelToDataSet(virtualPath, sqlQueryStatement);
                DataTable dt = ds.Tables[0];
                sqlConn.Open();
                using (SqlBulkCopy sqlbc = new SqlBulkCopy(sqlConn))
                    sqlbc.DestinationTableName = "BOM";
                    sqlbc.ColumnMappings.Add("Material", "Material");
                    sqlbc.ColumnMappings.Add("Plnt", "Plnt");
                    sqlbc.ColumnMappings.Add("Level", "Level");
                    sqlbc.ColumnMappings.Add("Item", "Item");
                    sqlbc.ColumnMappings.Add("Component", "Component");
                    sqlbc.ColumnMappings.Add("Object description", "Object description");
                    sqlbc.WriteToServer(dt);
                    Response.Write("数据导入成功!");
        catch (Exception ex)
            throw ex;
复制代码
演示:
下面内容于2017-10-17 14:38分添加:
使用sqlDataReader来导入,没有做过多的测试,速度与DataSet快不了多少:
复制代码
private OleDbDataReader ImportExcelToDataReader(string virtualPath, string sqlQueryStatement)
        OleDbConnection oleConn = new OleDbConnection(excelConnectionString);
        OleDbCommand oleComm = new OleDbCommand(sqlQueryStatement, oleConn);
        oleConn.Open();
        return oleComm.ExecuteReader();
复制代码
SqlBulkCopy的方法:
复制代码
        SqlConnection sqlConn = new SqlConnection(cs);
        OleDbDataReader reader = ImportExcelToDataReader(virtualPath, sqlQueryStatement);
        using (SqlBulkCopy bulkCopy = new SqlBulkCopy(sqlConn))
            bulkCopy.DestinationTableName = "BOM";
            try
                sqlConn.Open();
                bulkCopy.WriteToServer(reader);
                Response.Write("数据导入成功。");
                Console.WriteLine(ex.Message);
            finally
                reader.Close();
                sqlConn.Close();
复制代码
该文章在 2017/11/16 23:48:37 编辑过
